engine alarm question for HP500 EFI experts >
Old 07-17-2006 | 06:57 AM
GOODT's Avatar
Default Re: engine alarm question for HP500 EFI experts
if you have twin mtrs try swaping the ecms
GOODT is offline
Old 07-17-2006 | 09:34 AM
Talked to Merc Racing Tech Support this morning - they faxed me the discrete sensor test procedure for each of the sensors and wiring check. Problem is that this problem is intermittent, so not just simply a "bad" sensor. Tech Support also recommended swapping ECM's to see if it follows the ECM (if it does, a new one is $$$$, just to make the alarm stop !). He thought maybe more like a rubbed thru wire that is grounding out (he did confirm that the circuits are normally open and close to ground when a problem is present). Next time out, I'll try disconnecting the tan/blue wire on oil pressure switch if I can get to it (without inflicting to many cuts or contorsional maneuvers). Temp is monitored thru the same one that goes to the gauge, per Tech Support, so I think I can rule that one out. If all else fails, I'll disconnect power to that buzzer before I buy a new ECM and use the "redline" feature of the gauges!
Thanks,
Bob
bob_t is offline
madbouyz
6
05-04-2007 10:13 AM
FormulaM2Formula
0
03-28-2007 10:22 AM
26sonic
15
06-18-2004 01:05 PM
Adivanman
1
11-30-2002 03:53 PM
Adivanman
1
11-08-2002 05:37 PM
