Help needed with drive choice >
Old 07-20-2006 | 05:07 PM
Strip Poker 388's Avatar
Rob
Default Re: Help needed with drive choice
Check with Dean at the Bravo Shop on his B Max HT drives for your heavy application,
www.bravoshop.com
http://www.bravoshop.com/diesel_series.html
Better ck the warrenty and see if they will cover them at that weight
Strip Poker 388 is offline
Old 07-21-2006 | 01:36 PM
Reed Jensen's Avatar
Something as heavy as 17 thousand pounds.......... Go with Arneson drives. You NEVER hear horor stories about Arneson drives breaking at 300 hrs. You DON'T need to modify them .... you DON'T need to put showers on them.
Reed Jensen is offline
Old 07-23-2006 | 03:39 PM
Smile Re: Help needed with drive choice
With the Konrad ACE system, the transmission goes in the extension box outside the transom so inside space should not be a concern. I think with you application, Konrads many commercial diesel applications would give you a long lasting drive package. Arnesons are good strong dives also, especially behind diesels, I am just not sure they would be the best configuaration for your use type.
Ray @ Raylar
Raylar is offline
Old 07-25-2006 | 06:41 AM
Biggus's Avatar
Ray is right on the money. Konrad has done literally hundreds of diesel applications and I feel we have what it takes for a successfull application.
Give Fred a call at Konrad Marine 715-386-4203 he's very much intune with the diesel market.
[email protected]
Biggus is offline
35 White Lightning
Fountain
1
05-14-2007 12:03 PM
SledgeHammer
6
06-04-2003 04:43 PM
Donzi38ZX
27
01-03-2003 01:18 PM
blue thunder
16
11-17-2002 06:19 PM
panteraracin
3
02-07-2002 10:36 PM
