speed w/heavier outdrive oil
Originally Posted by Hydrocruiser
I think Amsoil makes a great product for most applications but if you are sending mega HP and Torque through a Bravo nothing is gonna save the day it would seem.
I personally think a Bravo can handle 500 HP and remain durable..that's about it in my books..
Originally Posted by checkmate454mag
Looks like alot of us will be getting gears treated this winter. Maybe we are on the verge of a beak through in longevity here.
Smitty,
I am not too concerned about the uppers. They seem to be able to hold up. At least, better than the lowers. I not running near the power you are. 680 hp, 660 torque. I ate up a set of lowers last season in 17 hours. However, I think they were just set up wrong. This winter, I set up new gears, bearings, etc, in the drive myself ( well, with help over the phone from Mr Gadgets ). So far, approaching 40 hours of pretty hard running with no issues and clean oil. If I can get the season out of them, I would be happy enough. BUT, if this process works, maybe I can get 2 or 3 years from a set of gears. That would be great. My only concern is the fact that you have to have a slightly used set of gears treated. That complicates things. If thats the way to do it, I guess I will have to get a new set of gears and set them up just before the end of the season to get a few hours on them.
Actually, I am in the market for a -2 Imco lower. I would love to test it out. Hopefully, 1 will surface before the end of the season.
Vinny
Vinny
Vinny,I started out with used gears in case they self destructed the first time I leaned on it but I also thought it might be a good idea to use ones that had a little run time on them too. After they were re-heatreated you couldn't tell they were used though. They went on shafts pretty tight too but the max worx shafts I used have always fit tight anyways. I think the heat treating would work on new ones too but I'm slightly concerned if they had no wear whatsoever on internal splines they might not fit,Smitty
