Stroked 540cid - 650HP Eating Oil????  HELP!! >
Old 07-18-2017 | 08:52 AM
  #41
F-2 Speedy's Avatar
and the 500 EFI pcv sets right in the middle of the lower intake and is vented to the upper plenum, pretty sure ?
F-2 Speedy is offline
Old 07-18-2017 | 11:52 AM
  #42
SB
Originally Posted by 1MOSES1
All 16 plugs look like this after 1.5 hours run time...these were brand new plugs.
https://i.imgur.com/t8ZEl7r.jpg
looks excessive for rings...idk
Embedded above pic into the post
SB is offline
Old 07-21-2017 | 06:56 PM
  #43
This is start up. Remember only had valve job..
https://youtu.be/prnx0vRqBwg
1MOSES1 is offline
Old 07-22-2017 | 07:00 AM
  #44
Originally Posted by 88bullet
you are having the same problem.... i ran across that last year on a friends 500's. the windage tray was left off the intake and it was eating oil like crazy. bad enough to foul the plugs every time we went out and ran hard. we left the pcv valve in the back of the intake but blocked the intake port and removed hose. not a drop lost since. try that and see if it solves your problem. that tray IS necessary.
X 2.. I built 2 454s for a customer, all ran fine, until he changed the intakes, then horrendous oil consumption... he thought WTF.. I went to his boat did some checking and found exactly THAT!! he had swapped his daul plane intakes for 500 HP carbs and intakes (pcv in valley) in order to run a PCV valve in the valley of an intake manifold it is mandatory to run a valley pan, this keeps the oil spray off the camshaft from hitting the bottom side of the intake thus getting sucked up in the pcv... no matter what valve you run the only fix without pulling the intake is to eliminate the pcv... we plugged the lines at the carb base and not a drop of oil consumption since!! Just backin you up Tim!!
adk61 is offline
Old 07-22-2017 | 07:05 AM
  #45
Originally Posted by hammerdown500
I have the same issue on my new 500 efi clone. Any idea if this could be my issue aswell. I know it does not have a liftervalley trap installed was told by the builder that it was not needed
change your builder... old school 101, a valley pan also keeps your intake temp lower by keeping hot oil from hitting it... I run them or something similar like an intake with a built in valley shield/baffle on all performance builds!!! just my 2 cents!!
adk61 is offline
Old 07-22-2017 | 07:12 AM
  #46
Originally Posted by SB
Windage trays and valley trays are two different animals. I would double check that the lifter valley tray (subject of this thread) was re-installed.
Chevrolet Performance Lifter Valley Baffle # 12555320
windage tray bottom end... valley pan top end... lol
adk61 is offline
k24u
6
11-27-2006 07:32 PM
Pat McPherson
17
11-01-2006 06:29 PM
1BIGJIM
5
06-05-2005 09:51 AM
dodsonartic1
4
10-17-2004 10:15 AM
checkmate981
9
05-17-2002 10:00 PM
