trim hose
Old 07-24-2006 | 05:26 PM
Default trim hose
I had a hydraulic trim hose go out on me, the long one that runs from the pump to the outdrive connector, does anyone know if the stock part from mercruiser will fit all applications? Its a 40' boat, and the stock part is 47inches, I am sure I need more lenght that that. Anybody have an idea? 40 excalibur hawk 454 trs, oildine pump 7/8in hose connectors.
thanks
spk1 is offline
Old 07-24-2006 | 07:52 PM
Default Re: trim hose
N/M, had some custom made.
spk1 is offline
Old 07-24-2006 | 09:06 PM
Have a custom made stainless braided hose made.
ActiveFun is offline
Old 07-24-2006 | 11:56 PM
exactly, thanks Active, I will add to the shop that they be stainless braided.
spk1 is offline
Old 07-28-2006 | 02:12 PM
Just thought I would post this for anyone who might need it.
That hydraulic trim hose that runs from the pump to the TRS out drive, has a connector about half way through the engine bay, so the mercruiser hose that shows on 47cm will work for a larger engine compartment, hehe After I took the connector and all the stubborn fittings off of the drive, I got into the engine compartment, and found that out, , that was the easiest hose I have ever replaced,,,,, the hardest hoses I ever had to replace, were the ones my dumbazz took off that I didnt need to, way to turn a 15min job into a 2hour job.
spk1 is offline
jbutah
9
07-31-2007 12:48 PM
Shooter
2
05-10-2004 06:50 PM
Blue by You
7
04-23-2004 07:34 PM
Danny_Ocean
0
04-16-2004 11:43 PM
32fever
6
08-14-2002 03:11 PM
