velvet drive fluid level ? >
Old 07-25-2006 | 08:24 PM
Unhappy velvet drive fluid level ?
Should you check the fluid level with the motor running or shut down ? hot or cold?
bryan24aero is offline
Old 07-26-2006 | 03:23 AM
MOP
Default Re: velvet drive fluid level ?
Check it in the same manner as you check your engine oil engine off.
Phil
MOP is offline
Old 07-26-2006 | 06:08 AM
Thanks for the help.
Old 07-26-2006 | 07:54 AM
Excalibur Dude's Avatar
Hello,
I asked that question yesterday. The way I was told to do it was while the drive has been in use (warmed up, hot, what ever you want to call it) you shut the motor off and run back and check the level. Thats what the guy at Velvet drive told me anyway. http://www.velvetdrive.com/ He said its almost a 2 man job. I think he said you want to get it before the oil bleeds back from your system...coolers and what not. He said its not a good Idea to check it while its running cause its slinging oil so much inside. Mine has the older Dip stick on it.
They have a tech support number.
Excalibur Dude is offline
Brad Zastrow
Swap Shop
0
10-23-2008 09:30 PM
wannabe
Drives and Lower Units
10
02-19-2008 08:49 AM
smdude
6
11-08-2007 02:04 PM
Excalibur Dude
12
08-31-2006 12:44 PM
Monty
6
02-26-2004 05:30 PM
