TRS vs Bravo >
TRS vs Bravo
TRS vs Bravo
Old 07-31-2006 | 08:57 AM
crazy canuck's Avatar
Default Re: TRS vs Bravo
Lofty ,is there spacer plates available for the Konrad ? Why i ask is because I am in the process of raising my drive line up 4" because of the buried TRS ,it measured 8" prop center to running surface ,final measurment will be 4" .later on when i build some real power and need stronger drives will i be able to achieve the same prop centerline to running surface with the Konrads.I hear that the Konrads are just under 2" shorter than the TRS.The boat is a 30 scarab with blown 454's at present.
crazy canuck is offline
Old 07-31-2006 | 04:10 PM
Hang Time 27's Avatar
Lofty, any info on that pantera swap as far as what kind of difference it made(other than the fact that it will hold some serious power)?? Was it a TRS boat? I haven't heard any results on single engine swap yet............
Hang Time 27 is offline
towhead
Drives and Lower Units
2
03-07-2008 03:11 PM
Russ G
3
07-25-2006 11:41 PM
lost2a6
19
11-18-2005 12:09 PM
Excalibur
1
07-22-2002 07:28 PM
