prochager problems continued 7.4 mpi >
Old 07-28-2006 | 11:50 PM
snake plissken's Avatar
Angry prochager problems continued 7.4 mpi
ok on my last post i had mentioned i had put my boat in the water for the first time since adding on a m1 sc procharger its making a beeping sound i checked all fluid levels and the tempeture is fine now that i removed the thermastat ok the boat wont go over 3000 rpms feels like it reaches a governer in a car it idles fine starts right up sounds healthy just seems like something holding the engine back what the beeping be the same problem any answers would be great its a Donzi 22 zx 1999 7.4mpi 310 hp
snake plissken is offline
Old 07-29-2006 | 09:36 PM
Default Re: prochager problems continued 7.4 mpi
Hi
I am no mechanic but could it be that you are leaking boosted air before it enters the throttle body...perhaps somewhere before or after the intercooler at a hose clamp joint? Or even the intercooler itself?
regardss,
Richard
Scarab29AUS is offline
Old 07-29-2006 | 09:46 PM
GOODT's Avatar
fuel regulator????? give me a call tomorrow sat nite ect we will go through what you should check.....
GOODT is offline
Old 07-30-2006 | 01:24 AM
It was blowing oil out of my dip stick tube so it seems like plenty of preasure and its getting about 40lbs of fuel preasure whens a good time to call goodt my mechanic called procharger and they told him to test it without the belt from the blower then clear any codes?? then try it again after with the belt back on any ideas? im taking it back on Monday and im sure any ideas or help he can use it thanks
Old 07-30-2006 | 04:47 PM
SB
Purely wild guess but this happens a lot when working on an engine:
Knock sensor unplugged ?
SB is offline
mats
45
07-02-2024 11:27 AM
sorrento454
5
06-30-2005 02:34 AM
mats
8
04-27-2003 08:53 AM
mats
8
10-11-2002 06:43 PM
hauling ass-a
14
07-11-2002 07:04 PM
