Pre alpha outleg >
Pre alpha outleg
Pre alpha outleg
Old 07-30-2006 | 11:17 AM
Default Pre alpha outleg
Mercruiser pre Alpha outleg. Changing water pump impeller. I can get the bolts off the gear casing and the lower casing separates about a 1/2 inch. Then no more, should the Leg be up or down and in or out of gear. Or what am I doing wrong, suggestions please.
alasdair is offline
Old 07-30-2006 | 12:43 PM
GOODT's Avatar
Default Re: Pre alpha outleg
the shift shaft I guess is what you are calling a leg should not matter comming apart......if you have all the bolts off and its dropped down at all its just hanging up somewhere may be water pump tube or the shift shaft is hanging up but it just slides over the lower shift shaft
Id post a pic but as a trial member you wont be able to see it
GOODT is offline
deboatmon
39
06-05-2009 11:55 PM
spazboz
Swap Shop
0
07-14-2008 10:42 AM
deboatmon
38
01-09-2007 07:24 AM
Steve_H
01-26-2003 11:14 AM
