MSD ready-to-run Distributor pn 8360
Has anybody used one if so how does it work? It seems very simple no box needed.
Re: MSD ready-to-run Distributor pn 8360
It is what I am using. No complaints so far.
You will want to experiment with the timing curves, changing the springs in it is simple, but the stop bushing is a little of a pain. I have only had mine this season, so I do not have a long term report. Another one you may want to consider is the D.U.I. Marine HEI. its a few $ more (I think like $30 or so) but has the advantage of intergal coil, easily obtainable parts, and from what I hear a better reliability record than MSD stuff. http://www.performancedistributors.com/marinedui.htm http://www.tpmarine.com/index.asp?Pa...ROD&ProdID=640 |
What power and boat are you running.
I am running a 388 SBC w/10.5:1 compression, Dart heads, guessing around 400 ponies. (a very similar street build (same cam, but with less compression and not as good of heads, but w/headers made 450 horse on dyno)
It is in a 24' Four Winns Liberator. Heavy and inefficient hull. |
8360 is just the std ready to run automotive distributor. It will not take the marine enviroment for long. I have a customer that has 20 hours on his brand new 8360's and both are so corroded that they are going to have to be replaced. Needless to say he learned a $600 lesson. I would buy a marine specific distributor.
Oops, I am running the marine RTR version. Methinks it is 8366. |
I'm using 83606 on my HP 500 with a Blaster coil. No issues.
I put one in my 400 SBC powered fishin' boat and had the module fail leaving me stranded. The module is under the breaker plate and is not field serviceable. I bought a non-rtr dist. and 6m2 box to replace it and carry the rtr as a spare.
| All times are GMT -5. The time now is 09:14 AM. |
