can this be hot tanked? >
Old 08-16-2006 | 04:19 PM
Default can this be hot tanked?
can this head be hot tanked?
I just got this boat motor was rebuild last year
Ron
http://pg.photos.yahoo.com/ph/ronsil...m?.dir=4491scd
roooon2 is offline
Old 08-16-2006 | 04:33 PM
ratman's Avatar
Default Re: can this be hot tanked?
you can hot tank any block and heads, the head castings are the only thing worth saving, install screw in rocker studs, toss the rockers springs etc. replace with roller rockers and new valves and springs. keeping mind you can by new copletely assm heads for not a lot of money.
ratman is offline
Old 08-16-2006 | 04:40 PM
O were and how much?I'm in So.Cal.Orange co.
Hey if the heads are like this do you think the blocks ok
roooon2 is offline
Old 08-16-2006 | 04:43 PM
I don't have a lot of money Is there any way to save this motor
roooon2 is offline
Where did the H2O ( that caused the rust) come from ?
If the head is cracked , there's no need to hot tank it.
I'd be looking for the source of the H2O first.
JaayTeee is offline
Old 08-16-2006 | 05:27 PM
This is as far as I got the exhaust-manifold and cover to see what I am in for.
roooon2 is offline
Old 08-18-2006 | 02:00 AM
Reed Jensen's Avatar
You're in for a lot of fun. If the engine has been in salt water it will be nicely welded together. You won't know until it is totally disassembled.
Reed Jensen is offline
Old 08-18-2006 | 11:33 AM
David's Avatar
Finding someone with a hot tank may be your biggest issue. Most are long gone due to EPA regs. If you are near a place that does hot dip galvanizing, the solution they use to pickle stuff before actual galvanizing will clean them up nicely, too.
David is offline
Old 08-18-2006 | 09:42 PM
Default Re:Half way there?
Well got out my 2600 psi power washer and that worked great
all the rust off looks like it was sand blasted. unstuck the Valves
now if I could only get the pistons unstuck.
roooon2 is offline
klmken
2
07-03-2006 12:14 AM
HARRISONMIRAGE
12
04-18-2004 12:49 PM
Miss Bud
10-21-2002 09:22 AM
