Re: will hp500 valve cover fit on merlin heads?
Originally Posted by 98itrwhite
so they wont fit merlin cast heads?
I used the older cast aluminum ones if that makes a difference.
Originally Posted by KCHOTBOAT
Mine did not. The exhaust valves and exhaust ports where set up higher on my Merlin Heads than a stock GM head. I had to use tall valve covers to clear the rockers. This was a gen 6 setup if that matters and I did grind off all the oil drips before I tried to use the valve covers.
Different heads have different height valve cover rails. You'll really notice this on small block heads. As a heads up.
| All times are GMT -5. The time now is 03:10 AM. |
