-   -   Anyone got a diagram from mercruiser (https://www.offshoreonly.com/forums/general-q/138785-anyone-got-diagram-mercruiser.html)
dean51267 08-24-2006 04:38 PM
I am looking for correct oil house routing for a Gen 5, 454, bravo 1 application. I need to verify from mercruiser what I have is correct. Thanks.
Hydrolift 08-24-2006 04:55 PM
Re: Anyone got a diagram from mercruiser
1 Attachment(s)
This is from Mercruiserparts.com (454 MAG. BRAVO (GEN. V) GM 454 V-8 1996-1997
Hope it was what you where looking for...
Wobble 08-24-2006 07:50 PM
The block adapter and the remote filter mount should be labelled with arrows or in/out.
it is very important to get this right, some filters like the k&N have check valves built in so incorrect flow would mean all the oil would bypass the filter through the block.
Also it is very important that the 30psi bypass valve is installed in the block (or plugged) a regular automotive one (15psi I think will allow oil to bypass the filter through the block)
Read this thread by articfriends http://www.offshoreonly.com/forums/s...ssure+problems
