Brad Penn oils... >
Brad Penn oils...
Brad Penn oils...
Old 09-19-2006 | 11:44 AM
Default Re: Brad Penn oils...
Spectro also uses the penn green oil, i have heard that it is the best for lubrication, but as Kurt said I'm not sure the additive mixture is whats needed for boat apps. I have plenty ofMobil V-twin 20-50 and will continue with that.
I have been using Spectro products for over 20 years in every motor that I own; car,boat, motorcycle, watercraft and sled. The only "green" oil that Spectro blends is their 2-cycle oil. Most finished lubes are an amber color, the "green" is nothing more than a dye that the blender will add. The dye is very helpful in premix applications to show that oil is mixed with the fuel. If you are draining you engine oil after "X" hours and it is still "green", don't use it. The oil is not doing it's job of holding contaminates in suspension to allow them to get drained out at the oil change. Ken
minxguy is offline
GOODT
05-24-2006 01:11 PM
Biggus
1
10-09-2005 05:40 PM
Biggus
9
09-13-2005 10:26 PM
WES311SR1
09-26-2003 09:29 AM
