How to tell difference between heads?
How can you tell difference from d-port, oval, square port heads?
Re: How to tell difference between heads?
I don't know which numbers to look at on the outside of the head. The ones I have seen are cast into the head under the valve cover.
Some where I have a link of which numbers are which heads. I'll look for it. Here it is. http://www.mortec.com/bbc.htm |
2 Attachment(s)
D port head most people are talking about the exhaust port shape. Peanut ports are very small intake ports about the size of a golf ball. Oval port are also talking about the intake ports, they are about the size of a 1 1/4 hose. Finally the square port or rectangular port is large from top to bottom of the intake runner. Its name is its shape.
John S. The first picture is a standard oval port, the second is a rectangular or square port and the peanut isnt shown but is another 1/3 smaller than the oval port. Hope this helps. :D |
Thanks for the lesson, good info to know.
| All times are GMT -5. The time now is 12:25 PM. |
