Slight miss? >
Slight miss?
Slight miss?
Old 09-03-2006 | 06:10 PM
Default Slight miss?
hey guys maybe someone here can offer some direction. Was out on the boat today and at low rpm the engine developed a slight miss. When I give it throttle it stumbles a tiny bit then is fine, come up on plane and runs out fine. It runs fine from about 1200 rpm up. Below that it misses, doesn't seem to be the iac valve, it feels and sounds like a fuel problem but could be ignition..the motor is a 2001 7.4mpi
tzrider is offline
Old 09-04-2006 | 02:01 AM
mats's Avatar
Default Re: Slight miss?
You can check with a timing light if it is the ignition and if it relates to a specific cylinder. May be somewhere on the secondary side of the ignition, dist cap, plugwire.
mats is offline
Old 09-04-2006 | 02:16 AM
99fever27's Avatar
Ive had a similar problem, hard starts poor idle and slow response at low RPM. If your tack is jumping at all replace the coil..worked for me.
99fever27 is offline
OSO News
Offshoreonly Industry News
0
02-19-2008 08:45 AM
checkered
6
10-10-2007 09:36 PM
CigDaze
12-11-2006 07:14 AM
28Profile
4
06-30-2005 06:41 PM
