Cutting open a oil Filter >
Old 09-04-2006 | 04:22 PM
CNC's Avatar
CNC
Default Cutting open a oil Filter
Anyone have a trick way of cutting open a oil filter w/out contaminating the results??
CNC is offline
Old 09-04-2006 | 04:39 PM
RLW
Default Re: Cutting open a oil Filter
I suggest an oil filter cutter. Here is the one I bought.
http://www.aircraftspruce.com/catalo...lcancutter.php
RLW is offline
Old 09-04-2006 | 04:48 PM
cuda's Avatar
I just put mine in a vise and cut it with a hacksaw. You will be able to tell the material from hacking it open. It will be on top of the element, and in my case was white. If you see the metal flakes of death, you will recognize them.
cuda is offline
Old 09-04-2006 | 05:32 PM
blue thunder's Avatar
I use a hammer and chisel. Cut right at the steel base with the bevel of the chisel facing the base. Go all the way around and the can slides right off.
BT
blue thunder is offline
Old 09-05-2006 | 03:42 PM
ericaull's Avatar
A large tubing cutter...looks like a C-clamp with a cutting wheel....ask your plumber.
ericaull is offline
Old 09-05-2006 | 06:27 PM
Elite Marine's Avatar
Sawzall at the base with the filter base down, cheap and effective. Pull off the canister and "read" your fortune or misfortune!!
Elite Marine is offline
Velocity Vector
0
04-03-2008 01:45 PM
powerguy
5
08-04-2002 07:44 PM
powerguy
Fountain
2
08-04-2002 05:17 PM
