Winterizing question? >
Old 09-07-2006 | 12:35 PM
Jerry B
Default Winterizing question?
I have a 29 foot Fountain with twin 502"s. I'm a big guy so I'm afraid if I get down there to the block drains to open them someone will have to call 911 to get me out. I have easy access to antifreeze so here is my question. If I put the drives is barrels filled with antifreeze and run the engines untill operating temp will this be good enough? I figure I can check the protection level of the coolant in the barrel since it will be mixed with the water that is currently in the engine.
Thanks, Jerry.
Jerry B is offline
Old 09-07-2006 | 12:40 PM
Default Re: Winterizing question?
yes you can.but save your money first.fill the barrels with water let run untill warm then add the antifreeze other wise your just dumping it on the ground.don't forget to fog the motor at the same time.just my 2cents
sonic28 is offline
Chris288's Avatar
yes
Chris288 is offline
Old 09-07-2006 | 12:44 PM
wrinkleface's Avatar
Jerry, just bought a winterizing kit at West Marine on sale. Check it out, might B easier than the barrel thing. U need that and some lower unit muffs and the rv koolaid. Good luck
wrinkleface is offline
Old 09-07-2006 | 12:50 PM
but what's the trick to getting fogging oil in an EFI motor.....
cloudmaster_321 is offline
Old 09-07-2006 | 01:53 PM
carney's Avatar
Put two oz of two stroke oil in the fuel filter
carney is offline
Old 09-07-2006 | 02:37 PM
that's bogus, what's the point of fogging my snowmobile engines then, or lawnmowers, or any other two stroke engine for that matter if the oil that is used is supposed to suffice for storage? Fogging oil is much stickier and adheres to the cylinder walls and what ever else parts for that matter, 2 stroke oil will eventually run down to the pan after time. My opinion, take it for what it's worth.
Old 09-07-2006 | 02:46 PM
Working on this myself.......
http://www.offshoreonly.com/forums/s...d.php?t=139493
Pismo10 is offline
Old 09-07-2006 | 02:48 PM
and
http://www.donzi.net/forums/showthread.php?t=46473
Pismo10 is offline
Old 09-07-2006 | 02:50 PM
Spraying fogging oil past the air mass sensor seems the answer. Is there anything downstream that should not get covered with this oil??
Pismo10 is offline
