winnterizing/ethanol >
Old 09-07-2006 | 03:30 PM
ok what do you do run the tanks dry or use stabelizer and let it sit for 7 months.i'm sure this will be an issue.
sonic28 is offline
Old 09-07-2006 | 04:58 PM
Default Re: winnterizing/ethanol
This might help?
http://www.offshoreonly.com/forums/s...d.php?t=139855
post #13 quote from Mercruiser manual.
Hydrolift is offline
Old 09-07-2006 | 06:20 PM
Pump it dry to the bone and fill up in the spring. I learned the hard way. I disconnect my fuel line and manually turn on the fuel pump to pump out all remaining fuel and put it in the truck.
jeffswav is offline
Old 09-07-2006 | 07:52 PM
Chris288's Avatar
I try to run mine down as far as possible I.E. less than 20 gallons and stabalize whatever is left, fill up with 80+ fresh in the spring..
Chris288 is offline
Old 09-08-2006 | 03:40 AM
Payton's Avatar
Charter Member #927
That'as what I do. I have not had a problem. I use Seafoam as a conditioner or stabilizer.
Payton is offline
myturn
18
11-08-2008 08:03 AM
plumbers crack
03-11-2008 02:23 AM
docmanrich37
40
02-19-2008 07:13 AM
scarab600
1
04-19-2007 06:37 PM
t500hps
07-21-2006 05:02 PM
