Engine noise >
Engine noise
Engine noise
Old 09-10-2006 | 07:49 PM
Registered User
Default Re: Engine noise
Originally Posted by nordic95
Pulled the motor yesterday and I think I found a problem.Looks like someone forgot to drain the block last winter.Time to order a long block,its probably not worth looing for just a block and switching everthing over,or could it be?Tell me what you think.
Nordic95
Odds are that you get get a long block or a low hour take out for near the cost/time/labor that you will have in taking apart and putting back together the one that you have. You are just looking for a standard SB chevy, not any exotic high performance BB.
the duke is offline
Old 09-10-2006 | 07:56 PM
nordic95's Avatar
Only looking for stock power,I'm thinking the same thing,I'm finding rebuilts for 1500 to 2500.Not worth messing with old motor,except old motor only had 87 hours,female use on it.Hate to throw it away.
Nordic95
nordic95 is offline
Old 09-10-2006 | 11:16 PM
Registered User
Nordic95
JB Weld/Marine Tec the crack
Yea, that the problem. A simple no winterize, and a bunch of good parts sit there and are worth very little. Got any junk yards around that have any blocks for a couple hundred? Or just take the motor apart, and keep the internals in case anything on the rebuild every breaks. rods/heads/pistons/oil pump etc
the duke is offline
Old 09-11-2006 | 06:50 AM
Mike Paula's Avatar
Would the wrist pin gouge the piston bore?I'm thinking the motor sat for years,maybe stainless pin adheared to piston then when started it gouged it up.Would the wrist pin noise go away at idle and up to 2000 rpms?I'm ripping it apart tomorrow and we shall see what happened.
Thanks Nordic95
I have seen pressed in pins make noise with change in load. Dont look like that was your problem though
Mike Paula is offline
Old 09-11-2006 | 06:55 AM
Mike Paula's Avatar
Nordic95
Keep it as a chandelier
Old 09-11-2006 | 06:46 PM
TomZ's Avatar
You cannot go wrong with the GM crate 350. All new parts and basically ready to drop in. Snatch the heads and add Felpro stainless head gaskets and you're set. Add a cam and you'll make a little more power. I think the cost is less that $1500 from Summit.
TomZ is offline
Old 09-11-2006 | 07:34 PM
nordic95's Avatar
I took the engine to a local shop that does marine engines.$1800.00 for them to take old engine apart,mic all pieces,all new bearings and pistons with rings,assemble complete engine with marine gaskets in one of there blocks including all machine work with 1 year unlimited hour warranty.Their shop is only 30 minutes from me and I couldnt beat the deal,lets see how it works out.Best part is I droped it off today and will have it back on Fri.
Nordic95
nordic95 is offline
Old 09-12-2006 | 07:02 PM
dont you already have alot of leftover used parts from your last two rebuilds that you can use ??
otis311 is offline
Old 09-12-2006 | 08:33 PM
nordic95's Avatar
NOPE,this project is a small block,other project is BIG BLOCK.I just cant get the parts to bolt on.
nordic95 is offline
hantunca
Chris Craft
7
09-21-2007 05:49 PM
Lickitysplit
Powerplay
37
04-07-2007 06:11 PM
Jamie Bowman
22
10-23-2006 08:14 PM
boatputz
3
09-17-2006 10:53 PM
johnlor
3
09-09-2005 12:18 AM
