Camshaft dilema. Help me decide where to go next.
SubscribeSB
close
- Join DateNov 2004
- LocationOn A Dirt Floor
Liked:3,708 Times in 1,693 Posts
Many engine builders won't deal with flat tappet anymore.
A few will relectuntantly and usually only if they can choose which core, lifters, and what type of oil you run. They'll still squint putting it together.
Quote:
You are pretty close, but I think I can do it a little cheaper than that. It all depends on where you get the parts. I`ve got a good connection. I can get all my parts at wholesale / jobber or less.Originally Posted by PatriYacht
It is a pretty expensive conversion. Cam, lifters and pushrods are about 1000.00 a set.
Griff
close
- Join DateOct 2000
- LocationOmaha/LOTO
Liked:2,512 Times in 1,250 Posts
Quote:
I really doubt you can get a roller cam, roller lifters, timing set, valve springs, pushrods, retainers and locks for much less than 1k, but good luck. Thats whats needed. Using all Crane parts through Summit, it ran me about $1300.
SB
close
- Join DateNov 2004
Yes, definately tough to do much cheaper unless standard quality stuff is used or as Don said 'connections'
Timing sets i get are typically around $100.
Pushrods I get are typically around $120-$160
Lifters around $550
etc,etc.
It adds up quick but then I buy HD stuff, not just replacements.
.Timing sets i get are typically around $100.
Lifters around $550
etc,etc.
One advantage I have is someone has gone through these engines before. Already have Crane Gold Rockers, Good pushrods, locks, retainers and nice, tight true-roller timing chain set.
Griff
close
- Join DateOct 2000
Crane gold rockers are a stock item on 420's. The pushrod length is different for a roller cam/lifters. The lifters are longer, so the pushrods need to be shorter. The timing chain set is different as it incorporates a bearing system that must be used with a roller set up. Also, if the rockers have a lot of hours, they should be replaced also.
