Gil Exhaust
Old 09-27-2006 | 04:05 AM
cig1988's Avatar
Default Re: Gil Exhaust
Being winterizing is in the near future I would send the risers & manifolds back to Gil to be pressure tested. Unless your able to psi test the manifolds yourself. I'd put my $$ on the exhaust.
Out of couriousity, what heads are you running ?
cig1988 is offline
Old 09-27-2006 | 06:28 AM
Payton's Avatar
Charter Member #927
Look at the center devider in your Gil manifold. Take it off the boat. Make an adapter for a garden hose and put it on one of the hose barbs. Then cap the other one. That should give you enough presure o find your leak.
That is where mine was leaking and was able to be repaired.
Payton is offline
Old 09-27-2006 | 10:45 AM
gripit's Avatar
Stan,
I have no idea what heads are on there. I think they are the ones that came standard with the 420 hp package. I know it has Dart intake and Crane roller rockers etc. I checked the risers and manifolds and couldn't find any leaks. Payton, I can't find a leak. I hooked up to a gardent hose on full blast.
The thing I don't understand is how could both gaskets left and right side have leakage from a crack in a head? Also both oil caps had milkshake oil in the caps. So what could cause these symptoms. The engines have 650 hrs.
gripit is offline
Old 09-28-2006 | 04:16 AM
cig1988's Avatar
I would suspect the risers or a cracked head. I have 2 pairs off of the '88 & not sure if there any good. I would pressure test the block. I use a regular radiator tester w/an adaptor to a hose & engine full of water with some dish washing soap in it.
cig1988 is offline
Old 09-28-2006 | 07:35 AM
Biggus's Avatar
I've had bad luck with Gil cast manifolds. I'd be very suspect of your Gils.
Biggus is offline
Old 09-28-2006 | 07:22 PM
gripit's Avatar
Cool Re: Gil Exhaust
I'm very suspect of the Gils. I'm going to send them back to Gil to be tested before tearing into the heads. What are the chances it would be a craked head or cracked valve seat? Then again, I'll be pissed if gil sold me 2 new defective manafolds.
gripit is offline
Old 12-27-2006 | 05:20 PM
GRIFF
If Gil risers are stil available please email me.
[email protected]
THANKS!
RickR is offline
Old 12-30-2006 | 11:38 AM
Dtile's Avatar
I had simaler problem, thought the oil cooler was leaking but it was a bad head gasket (normal compression btw) and one a cracked gil. A piston finally detonated. Engine had only 2 hours on it. The water pressure in cly blew the gasket I would think.
Dtile is offline
formula 382 sr-1
0
10-07-2007 05:58 PM
gripit
2
01-08-2007 07:25 PM
Gary864
06-07-2006 06:39 PM
nocigarette
8
04-24-2006 06:59 AM
Dangerous Dave
5
08-02-2004 10:25 AM
