496 Mag HO Winterization >
Old 09-28-2006 | 09:59 AM
Question 496 Mag HO Winterization
Does anyone know where I can find step by step instructions for winterizing a 496 Mag HO??
Barnes and Noble was sold out of "Winterization for Dummies"
Feel free to post instructions if you have done it before.
CasinoRunner is offline
Old 09-29-2006 | 09:29 AM
Chris288's Avatar
Default Re: 496 Mag HO Winterization
My procedure:
1. grease trailer bearings, coupler, gimble
2.run fuel as low as possible, stabalize whats left...
3. start engine, get up to operating temp. Change engine oil and filter
4. Change gear lube.
5. pump out water with little blue pump.
6. start engine and run 2 gallons of pink RV anti-freeze through it and stop.
7. pull fuel filter, dump half the gas out of it and fill the rest with 2-stroke oil.
8. reinstall fuel filter, start engine run an additional 2 gallons of pink RV.
9. pump out RV with little blue pump.
10. Depending on how anal you are, pull each plug and squirt oil into cylinders.
11. Install fresh fuel filter.
I usually run between 40-60 hour per season, I do one oil and drive change per year at the end of each season right before winterizing..
Chris288 is offline
Old 09-29-2006 | 02:41 PM
Originally Posted by Chris288
My procedure:
U forgot to pull the 3 blue plugs out and remove the end caps from the heat exchanger.
bcolmsted is offline
Old 10-02-2006 | 08:47 AM
Chris288's Avatar
Why would I want to remove the end caps from the heat exchanger ??
Chris288 is offline
Old 10-03-2006 | 10:07 AM
If you have any sand or mud in there it will hold moisture and freeze ..resulting in a new heat exchanger...$750 plus..
Old 10-03-2006 | 12:22 PM
Chris288's Avatar
Thats the purpose of running the RV -50 degree antifreeze through it... I dont think your gonna find many people disassembling their exchangers for winterizing...
Chris288 is offline
Old 10-03-2006 | 02:08 PM
Its a 5 min job, I wish I would have done...
mg503
Baja
14
04-03-2013 04:50 PM
TeamPSI
23
12-10-2007 05:23 PM
apexer
11
07-20-2007 07:24 PM
westcoaster
3
08-08-2005 11:24 AM
NVRENOUGH
3
02-18-2002 12:25 PM
