496HO hot manifold >
496HO hot manifold
496HO hot manifold
Old 10-05-2006 | 06:52 PM
Default Re: 496HO hot manifold
My pump was scored at both the cap end, and the bottom of the housing, so I rebuilt it with a rebuild kit from R&R Products. It has stainless plates that go on both sides of the impeller. Real nice kit.
phebus is offline
Old 10-05-2006 | 07:12 PM
How long have you had your kit installed and how did the everything look when you replaced the impeller?
I intstalled the kit about the month ago and am curious to see how it holds up in the long run. Were you able to reuse the gaskets or did you install new ones?
Here is the kit we are talking about seems to be a better alternative to replacing the whole pump.
Attached Thumbnails 496HO hot manifold-water-pump-instructions-compressed.jpg   496HO hot manifold-water-pump-instuctions-2-compressed.jpg
turnerrd is offline
Old 10-05-2006 | 10:29 PM
Here is the kit we are talking about seems to be a better alternative to replacing the whole pump.[/QUOTE]
Where did you purchase the R&R kit from and how much did it cost? It looks like a slick improvement to the brass wear surfaces.
Escape Velocity is offline
Old 10-05-2006 | 10:30 PM
I just put it in this morning when I rebuilt the pump. It seemed the better alternative to replacing the pump due to scoring.
phebus is offline
Old 10-06-2006 | 04:34 AM
Where did you purchase the R&R kit from and how much did it cost? It looks like a slick improvement to the brass wear surfaces.[/QUOTE]
R&R is out of AZ and they sell them direct. 928-453-6411. I think it was like $150 about half prive of a new pump.
turnerrd is offline
Old 10-06-2006 | 10:39 AM
I live in Lake Havasu, and that is where R&R is located, so I purchased it direct. The kit comes complete with a new impeller, the plates, gaskets, and all new hardware. It is a very nice kit, and has very nice detailed directions with pictures to guide you through the install.
I hope the pump rebuild will fix my problem, as the pump had scoring at both ends, that had to effect flow and pressure.
phebus is offline
Old 10-08-2006 | 08:34 PM
Thanks for the contact info. I'll give them a call.
Jassman
Active Thunder
20
10-01-2007 08:45 AM
klmken
2
07-03-2006 12:14 AM
Nordicflame
6
01-10-2005 12:09 AM
HARRISONMIRAGE
12
04-18-2004 12:49 PM
