Bravo engine setup with an Alpha drive? >
Old 10-05-2006 | 12:57 PM
Default Bravo engine setup with an Alpha drive?
I have an Alpha setup with a 350,, I have the opputunity to pick up an almost new EFI 300hp 350 at a great price but t came from a Bravo setup.
I would think the only difference is the coupler,rear mount and maybe hoses which could all be swapped over frommy current engine but I wanted to make sure. Thanks in advance!
HTRDLNCN is offline
Old 10-05-2006 | 05:43 PM
Mbam's Avatar
Offshoreonly Advertiser
Default Re: Bravo engine setup with an Alpha drive?
There is no provision in the ECU on the EFI motor for the shift interrupt, you will not be able to get it out of gear, at least not easily/safely. It's do-able if you change the ECu and add the interupt switch.
Mbam is offline
Old 10-05-2006 | 06:05 PM
Thanks..
So the rest ,mounts,couplers,waterlines,etc would bolt up no problem?
HTRDLNCN is offline
Old 10-05-2006 | 07:33 PM
Mbam's Avatar
What year is the boat and new engine?
Mbam is offline
Old 10-05-2006 | 09:22 PM
Boat is an 89, Alpha 1 , current motor is a mid 90s 350/270hp Magnum (one piece rear main)
new motor is a 2002 350EFI.
HTRDLNCN is offline
Old 10-06-2006 | 05:46 AM
Mbam's Avatar
Yep, should go right in.
Mbam is offline
Old 10-06-2006 | 06:20 PM
MOP
Lightbulb Re: Bravo engine setup with an Alpha drive?
Do your home work on getting the ECU to work with the Alpha! Zinger on the Donzi board did his home work paid a fair buck and "Grenaded" the Alpha real quick.
MOP is offline
evaluex
3
04-10-2008 09:15 AM
evaluex
5
08-21-2007 11:03 AM
Ford Capri
8
03-18-2007 04:13 PM
dave911
22
08-31-2006 01:20 PM
Wally
12-06-2003 04:52 PM
