Code 81 on scanner - MEFI 4 >
Old 10-09-2006 | 09:26 PM
txriverrat2001's Avatar
Exclamation Code 81 on scanner - MEFI 4
OK - Got a 1999 33 Donzi ZXw/ twin 502 Mags - One motor ran great then all of a sudden lost power. I scan it and pull Code 81 - "A" bank Injector voltage high. Here's the odd thing - Scan the other motor and it's a MEFI 3. Take a good look at the other one and notice the EFI Harness from the ECM is plugged into another harness similiar to "piggybacking". Odd. The motor with the problems has only 34 hrs on the scanner - obviously it's been replaced. (MEFI 4) (Other - MEFI 3-has 130hrs)
Is it common to replace an MEFI 3 with a MEFI 4 and adapt w/ cables? I haven't run across many boats w/ECM issues other than the norm - IAC, TPS, etc... no actual ECM failures.
And if you have any experience w/ this code - any scenarios explaining the code?
Thanks for any input!!
txriverrat2001 is offline
Old 10-09-2006 | 11:03 PM
Default Re: Code 81 on scanner - MEFI 4
Thank God for Carbs.
ghittner is offline
Old 10-10-2006 | 10:24 AM
Dave_N's Avatar
The MEFI3 ECM's are no longer available. When they fail, the only option is to replace them with a "kit" than includes a MEFI4 ECM and wire harness adapters.
The problem is that the Mercruiser service manuals don't cover any of the additional trouble codes (like a code 81)of the MEFI4 ECM. The trouble shooting procedure below is from a Volvo service manual (unlike Mercruiser, Volvo did use the MEFI4 ECM on some of there late model engines).
Dave
Dave_N is offline
Old 10-10-2006 | 10:31 AM
Thanks - I did some more digging this morning with the help of a good friend @ a Merc dealer. History shows this engine has had two ECM's replaced, a harness replaced, multiple repairs concerning the knock sensor open/grounde etc....
This should be a fun one to figure out .......
Old 10-10-2006 | 12:23 PM
Yo Dave - I've received a fax with the DTC 81 codes - but need to verify which cylinders are "A" bank and which ones are "B" bank -
Any ideas?
Thanks again for your help!
Old 10-10-2006 | 01:08 PM
Dave_N's Avatar
I believe "A" bank would be 1,4,6,7 and "B" would be 2,3,5,8
Dave
Dave_N is offline
Warlock
3
11-01-2007 10:37 AM
ls1nova
6
01-16-2007 09:25 PM
Steve A.K.A RAMPAGE
12-20-2002 04:28 AM
