Another winterizing question >
Old 10-16-2006 | 12:43 PM
BajaRunner's Avatar
Default Another winterizing question
Not that i need to anytime soon
but,
I have the fresh water flushes (hose fittings) under the hatch. can you rig up a hose hooked to a 5 gallon bucket to get the antifreeze into the engine? looks like that would work, and i wouldnt have to open anything up on the engine.
BajaRunner is offline
Old 10-16-2006 | 01:01 PM
Wally's Avatar
Were doomed!
Default Re: Another winterizing question
Yes that would work.....depending on how its all plumbed up you would probably need to open some valves that those flush's are attached to before they go into you cooling system......
-Wally
Wally is offline
Old 10-16-2006 | 02:17 PM
baja36ft's Avatar
but,
yes jason that would work but i use a small pump to pump
it into the motor. and i never open up the motor.
stan
baja36ft is offline
Old 10-16-2006 | 07:04 PM
Payton's Avatar
Charter Member #927
stan
I have done it both ways, a small pump or a shut off valve to stop the flow out the drive and just let gravity do it's thng.
Payton is offline
Old 10-17-2006 | 07:12 AM
Leathl_WS6's Avatar
Wouldn't you want to get it up to operating temp so the T-Stat is open. Seems if you just pumped it in there would be reg water behind the tstat.
Leathl_WS6 is offline
Old 10-17-2006 | 08:52 AM
mats's Avatar
You need to empty the block first to be safe.
mats is offline
Old 10-17-2006 | 01:24 PM
baja36ft's Avatar
YES let the motor run on the hose till it reachs temp and then
change over to the anti freeze run 4 gals (not 50/50) and you are done
i never empty the block....
baja36ft is offline
Chart
3
11-01-2006 04:09 PM
DORaymond
7
11-13-2005 05:35 PM
G Man
4
10-22-2005 09:54 AM
OG Outlaw 24
10-08-2003 12:04 PM
283CHECK
4
11-05-2002 09:38 PM
