502whipple with bravo 1 >
Old 10-18-2006 | 12:49 PM
Elite Marine's Avatar
Default Re: 502whipple with bravo 1
I have an XR with 23 hours on it that is for sale.
I also sell the only drive with no failures to date. . . EVER.
KONRAD
Elite Marine is offline
Old 10-18-2006 | 06:46 PM
Grog's Avatar
Give the B1 a chance. I have 2 seasons on mine. Don't hammer it to get on plane and keep the drive in the water. Who knows...you may never have to replace it.
Grog is offline
Old 10-18-2006 | 06:58 PM
I will have one , possibly two professionally rebuilt Bravo 1's for sale soon if you are looking for spares.
RBeyer is offline
Old 10-18-2006 | 07:23 PM
If you stick with your bravo or even upgrade to an XR, make sure to change your gear fluid often...like every 10 - 15 hours. Guys have had great luck by doing this.
Old 10-18-2006 | 08:38 PM
Magnum25's Avatar
How much
Magnum25 is offline
Old 10-18-2006 | 08:45 PM
Originally Posted by Magnum25
How much
$2750 plus S&H. I have one for sure will tear into the other to see what it needs.
RBeyer is offline
Old 10-18-2006 | 11:45 PM
I've run my Bravo 1 since 1989 through 4 motors two of which were over 600 HP and ran at over 6000 RPM now I've run the same drive with 800+++ HP all this season with no problems and never once since 1989 have I ever had a problem other than changing a U-Joint. .... YES IT CAN HANDLE IT. BE NICE TO IT. Change the fluids EVERY season. It will be nice to you.
ghittner is offline
Old 10-19-2006 | 12:40 AM
With your luck, you should run out and buy a lottery ticket
Griff is offline
Old 10-19-2006 | 06:53 PM
It depends on the weight of the boat, type of water and like you stated, how you drive.
Try it and see is all I can say. A standard bravo lasted on my 24 Pantera with over 600 HP for 4 years. An XZ lasted 50 hours on my 28 Pantera with 600+ HP
Good luck!!
Old 10-19-2006 | 08:06 PM
Change fluids every season? How abouut every fiteen hours or so. Do you ever go on plane. I agree can I rub you and buy my lottery ticket.
RBeyer is offline
