Marine alternator >
Marine alternator
Marine alternator
Old 10-22-2006 | 12:33 PM
gripit's Avatar
Default Marine alternator
Is their a difference between buying a altenator from mercruiser or will an automotive one be the same thing?
gripit is offline
Old 10-22-2006 | 12:39 PM
jimjomack's Avatar
Default Re: Marine alternator
I replaced two of mine from a auto electric store in NJ. He had the exact same replacement as the mercruiser unit. The cost was 160.00. Had no problems. I also replaced the starters also from him. They are about 1/2 the price as mercruisers.
jimjomack is offline
Old 10-22-2006 | 05:42 PM
Grip,
The marine parts should be spark arrested or sealed to keep sparks from ingiting any fuel vapors in the closed engine compartment. I guess if you don't care about that you could use the automotive parts I dont suppose the CG or DNR would like it too much either if you ever got stopped for an inspection. Is the difference in price worth it ??
BillK is offline
Old 10-22-2006 | 06:37 PM
Mr Gadgets's Avatar
Charter Member #601
Gripit.
If you go to a decent Alternator rebuild shop they can build you one with the proper screens. I found a place that built one for me for $60. It is a One Wire GM alternator with the screens installed to make it CG approved.
Check around and ask questions.. I would think you can find a direct replacement or just have yours rebuilt..
Hope this helps
Dick
Mr Gadgets is offline
Old 10-22-2006 | 06:50 PM
gripit's Avatar
That is why I asked. I just wanted to know the difference. Knowledge is paramount.
gripit is offline
Old 10-22-2006 | 07:24 PM
DB electric on the net. They have 1 wire marine alts. for around $100. I've run one for over a year now.
kennyo is offline
baja27
0
09-23-2008 08:57 AM
David Stotz
11
12-16-2007 12:43 PM
itilldo
07-06-2006 07:44 AM
WHOSNEXT
15
09-30-2005 10:50 AM
timewarp
3
03-03-2002 09:31 AM
