Exhaust Drain Plugs >
Exhaust Drain Plugs
Exhaust Drain Plugs
Old 10-31-2006 | 01:43 PM
aquatictherapy's Avatar
Default Exhaust Drain Plugs
I was winterizing the boat, when I took the drain plugs out of the exhaust manifold, one of them just crumbled. The engine is a '99 502 with stock exhaust. Is there anything that I need to do to make sure none of the plastic clogged the line and where do I find a new plastic drain plug? Thnks for the input.
Scott
aquatictherapy is offline
Old 10-31-2006 | 03:34 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Re: Exhaust Drain Plugs
The plug is avaible from either a merc dealer, West Marine, Boat Fix, etc.
I always keep a few extras as the flange part always seem to break off. I usually can just tap a screw driver into the the plug body and unscrew it. Doubt it will clog anything if it crumbled as you say.
US1 Fountain is offline
Old 10-31-2006 | 05:14 PM
I found out from 9 years of using that blue wing nut that their a lot less likely to break if you just snug them slightly,the o-ring does the work. I think when their overtightened the expansion & contraction of the heating & cooling of the engine causes extra fatigue on them.
johnny b good is offline
synack
2
10-15-2007 11:38 PM
docmanrich37
Active Thunder
1
01-16-2005 08:30 AM
Sydwayz
1
11-09-2004 06:46 AM
Daryl
07-14-2003 10:17 PM
hp500efi
4
05-12-2002 02:09 PM
