Anyone Deal with Titanium Scrap ? >
Old 11-03-2006 | 02:33 PM
cougarman's Avatar
Default Anyone Deal with Titanium Scrap ?
Looking for ( 4 ) pieces
Finish size would be 6" x 6" x 1 1/2" Thick
Cougarman
cougarman is offline
Old 11-04-2006 | 04:31 PM
Strip Poker 388's Avatar
Rob
Default Re: Anyone Deal with Titanium Scrap ?
and how are ya going to cut it?
Strip Poker 388 is offline
Old 11-04-2006 | 08:03 PM
cougarman's Avatar
Originally Posted by offshore ginger
jon what are you going to use this for ? jon sues cousin deals direct with a lot of scrap yards that handle titanium nation wide . i talked with him just a little while ago , he will not be able to tell me anything untill he gets back to work on monday . your old friend , G . G .
Some spacers, titaium acts as an insulator.
So not only does in disapate heat well, it also does a good job not transfering the heat to it's mating pieces.
And it's light
cougarman
Old 11-04-2006 | 08:07 PM
cougarman's Avatar
That's the least of my worry's, it actually machines real nice with coated carbides and the right coolants.
Cougarman
Old 11-05-2006 | 07:12 PM
bblythe's Avatar
how much you need are you machining to size or me
bblythe is offline
Old 11-05-2006 | 07:41 PM
cougarman's Avatar
4 pieces 6.000 X 6.000 X 1.500 thick is finish sizes.
I'll do all the machining, so as long as the pieces are bigger than those dimensions I can bring them to size.
If there all in one plate I can cut them out to, just need to compensate for my cutter running in between them.
Cougarman
Old 11-05-2006 | 08:56 PM
Lofty's Avatar
Are you looking for 6al 4v? We have a pretty big stock left over from a DOE job we ran. I have some large drop outs but I'm not sire if they're that big. I'm out of town till Tues AM but will check when I get in.
Fionn
Lofty is offline
Old 11-06-2006 | 07:48 AM
bblythe's Avatar
there are about 300 types of ti. if you are using for spacers probably not a big deal all are good insulators have to cut from round call 219-240-2595
e-mail if needed
bblythe is offline
Old 11-06-2006 | 08:49 AM
cougarman's Avatar
Fionn
Not an expert on the metalergical end of Titanium, so if ya know the defference between the two please advise.
Will be dealing with some heat cycles............as high as 1000 degree's.
Cougarman
Old 11-06-2006 | 12:12 PM
Lofty's Avatar
6al 4v is the most common and is used widly in the aerospace industry. If you go to matweb you can look up all the differnt types and their properties. Just depends on the application.
Lofty is offline
