-   -   OUTDRIVE "B"ring "O"ut "A"nother "T"housand (https://www.offshoreonly.com/forums/general-q/144416-outdrive-b-ring-o-ut-nother-t-housand.html)
electrical1 11-04-2006 10:06 PM
Well finally got boat out of the water today and to my surprise the starboard outdrive was worse than I thought. A nice hole right through the side of the lower unit, about the size of a quarter.
So now I need a new outdrive. Maybe I'll break down and buy a set of Konrads. Who out there is giving the best prices, and is there anyone local to RI or is there only one place to buy them.
Tricky919 11-04-2006 11:08 PM
Re: OUTDRIVE "B"ring "O"ut "A"nother "T"housand
2 Attachment(s)
Here's the damage to my lower......
cig1988 11-05-2006 05:39 AM
Hey Vinny
What bad luck dude. In the Cig forum "cigrocket" may have what you need and he's in NYS I believe.
cigrocket 11-05-2006 07:23 AM
I have a complete LH TRS. The drive was purchased in 2004 from FRED CECIL (TRICK MARINE) The drive is complete freshwater. I changed over to Konrads. The drive was used on Cayuga Lake. I also have the Upper housing for a TRS. I sold all of my other parts. The drive was checked out by sterndrive specialists in upstate NY. The drive oil is changed every `15 hours of use with mercury high performance lube.
Lofty 11-05-2006 01:22 PM
We've got great deals on Konrads, give me a call or email and I'll send you the details. The conversion is painless and you'll be able to sleep for once knowing that you will never have to worry about a drive failure again.
We run them on our own Fountain and have had no problems after hundreds of hours of hard use.
Fionn
925.952.4240
electrical1 11-05-2006 01:27 PM
I clipped and pasted the web site you have for the trs outdrive and it takes me to e-bay but your drive isn't listed, just a couple of gasket kits. Question is the rotation in the transmission or the outdrive. Does it really matter left or right on the outdrive. the one that I blew turns clock wise, but I'm not sure if there is a difference between the two. are there any experts out there that can tell me.
Lofty 11-05-2006 01:51 PM
There are a left and right hand rotation drive. The difference is in the lower unit. If you look at the prop shaft you should see a L or R stamped in it. The Konrad is set up the same way.
electrical1 11-05-2006 05:47 PM
Do the motors need to be pulled, or do they bolt up to the gimbals of the trs
Before I commit to calling for the konrad drives what kind of money are we talking for a direct replacement of both drives. I heard of prices form 16000 to 22000 seems like the prices are all over the place.
cigrocket 11-05-2006 06:22 PM
The Drives Are Rh And Left Hand. The One I Am Selling Is A Complete Lh
Elite Marine 11-05-2006 06:32 PM
I can provide information and pricing on the Konrad conversions. I think you'll find that the pricing isn't as bad as you've been researching. The 540 PRS is a direct bolt on replacement for the TRS. They are bullet proof.
Send me your email address and I'll get you some info and a true "Buy" price. Also include your state/Zip so that we can include shipping costs.
Email to:
[email protected]
Thank you,
Kirk
cigrocket 11-06-2006 07:02 AM
I normally use clockwise (right) and counter clockwise (left) rotation for the actual way the prop shaft turns when viewed from the rear when the transmission is in forward.
But like I said above, check the prop shaft it is labled. The way you have described it. It sounds like the LH and that is the one I am selling.
Lofty 11-06-2006 12:42 PM
The motors do not have to be pulled. If your Merc gimbals are good there is no reason to pull them. You can install what Konrad call a half conversion. The kit consists of a drive and bellhousing. I can do this convesion in about 2 hours.
Call or email me and I'll give you the OSO members pricing on these. We've got the most competative pricing on these. If needed we can also come to you to do the install.
Fionn
cigrocket 11-09-2006 08:51 AM
Guess Electrical is not interested or discovered he needs a RH instead of a LH TRS
