problems with 500efi >
Old 11-06-2006 | 11:00 AM
Default problems with 500efi
i recenmtly had a 500 efi rebuilt problem supposedly was that engine took in water thru the exhausts. rusted and broken valve. now engine stalls at low speed and runs rough. any ideas
furnitureman is offline
Old 11-06-2006 | 11:35 AM
Default Re: problems with 500efi
Valve adjustment too tight, timing, IAC ?????
Griff is offline
Old 11-06-2006 | 01:00 PM
Maybe water getting to cylinder from exhaust did you fix or replace the exhaust.
brian41 is offline
Old 11-06-2006 | 08:56 PM
Michigan Mad Man
I would start by checking the base timing and that the Iac is opening and working properly. You did fix the water problem??
TylerCrockett is offline
t500hps
07-17-2012 09:23 AM
Strip Poker 388
4
02-24-2004 11:06 PM
CAP071
Sunsation
7
10-07-2003 08:13 PM
Donzi26ZX
05-30-2002 09:17 PM
