What should piston to wall clearance be
#41
Originally Posted by blue thunder
I don't think you've been lucky Kidnova. You always had a good tune, good cooling and good maintenance. That is why you never needed the insurance of extra clearances.
BT
BT
#42
Originally Posted by HPJunkie
Would ceramic coated piston tops add or subtract from the clearance? My builder said run 006 and another said run 0065. JE max is 0075. Out of 2 meltdowns none were from skuffing of the pistons to the cylinder. Both were detonation. This time I ceramic coated the pistons, chambers and Exhaust ports. I wonder if that was a mistake. Keeping the heat in the chamber might increase the detonation possibility. No teflon on the skirts though.
