Iron Eagle Heads Build Recomendations >
Old 11-20-2006 | 07:24 PM
gripit's Avatar
Default Iron Eagle Heads Build Recomendations
I want to build a set of Dart iron eagle 308 cc 119cc 2.25/1.88 heads with the best of the best stuff. Let's start with Manley S/D intakes and Inconel exhaust valves. I am using a Crane Roller Rocker CAM which is the 296 in a 454. My first question is how do I know what size to order?
gripit is offline
Old 11-20-2006 | 10:06 PM
GoCiggie31's Avatar
From: Where the water meets the oaks 'n Pines in the Sierra Nevada's of NorCal
Default Re: Iron Eagle Heads Build Recomendations
gripit,
sounds like a great project.
I am sure the pros here on OSO can give you some great guidance for your fun project.
My project is not as wild as yours so I had some very good luck with the crane tech line (904.258.6174) on my simple project.
I just installed the manley s.d.intakes and the manley e.d.(inconel) exhaust on my worked 088s. w/ a mild 132561 crane.
keep up posted
Attached Thumbnails Iron Eagle Heads Build Recomendations-myheads.jpg   Iron Eagle Heads Build Recomendations-longblockwrollers.jpg
GoCiggie31 is offline
Ken N
8
01-25-2010 12:23 PM
Blue by You
Swap Shop
11
01-30-2009 08:09 PM
