Antifreeze 496 >
Antifreeze 496
Antifreeze 496
Old 11-27-2006 | 10:58 AM
Default Antifreeze 496
When winterizing I checked the antifreeze and it was only good to 15 degrees..Prestone dexcool.
Its still pink in color but it must of got duluted down with lake water which means my heat exchanger is probably cracked.
I drained a gallon out and poured straight antifreeze in for the winter.
Is there anything else that would cause this?
bcolmsted is offline
Old 11-27-2006 | 11:39 AM
Rage's Avatar
Default Re: Antifreeze 496
What was the antifreeze's temperature freeze rating the last time you checked it before this and how long ago?
Rage is offline
Old 11-27-2006 | 01:37 PM
Last year, when I winterized it was good for below zero..Ive had a bad heat exchanger before and all the fluid in the resevoir was lake water..This is still the color of antifreeze.
Macklin
41
01-11-2008 07:42 PM
JMPH
19
12-18-2005 09:47 PM
inpropsicated
1
03-21-2004 12:50 PM
bajabob
Baja
17
10-03-2002 07:21 PM
Audiofn
32
10-03-2002 09:26 AM
