Imco Oil Change >
Imco Oil Change
Imco Oil Change
Old 11-27-2006 | 07:59 PM
sandman
Default Imco Oil Change
Can anyone tell me how to change the oil in an older imco outdrive? I see two plugs on the upper gearcase, one on the right side and one to the rear. I cant find a plug on the lower unit. Thaks, Casey
sandcraft is offline
Old 11-27-2006 | 10:54 PM
Default Re: Imco Oil Change
Isn't it behind the prop??????
Griff is offline
Old 11-28-2006 | 08:55 AM
Steve Zuckerman's Avatar
In the carrier bearing.
Steve
Steve Zuckerman is offline
Old 11-29-2006 | 07:14 AM
sandman
Thanks guys!
Old 11-29-2006 | 01:46 PM
You do realize that you have to pump new lube into the drive from the bottom also-----Don't you????????
Griff is offline
Old 12-01-2006 | 05:18 PM
sandman
does someone make a tool for doing this?
mike0311
07-18-2006 03:05 PM
Longrange4u
15
06-05-2006 02:44 PM
SkiDoc
23
12-22-2004 09:43 AM
mleslie951
27
11-08-2004 08:03 PM
jeffg
2
08-24-2003 09:01 AM
