Help with SBC identity >
Old 11-29-2006 | 12:29 PM
Default Help with SBC identity
I took the SBC out of the Monza for some re-rigging and want to identify it before I re-install. The block has the numbers GM3951511. Can anyone identify this block for me? The specs of the factory parts? Thanks
thedonz is offline
Old 11-29-2006 | 01:37 PM
rmbuilder's Avatar
MarineKinetics
Default Re: Help with SBC identity
Donz,
That is an early 400 block, most likely a 4 bolt, however they did make some in 2 bolt config. How long has it been run in salt?
Bob
rmbuilder is offline
Old 11-29-2006 | 05:52 PM
Thanks for the info Bob. The engine was run in fresh water for years. I purchased the boat last year and have run it in salt water on three occassions.
thedonz is offline
Old 11-30-2006 | 11:38 AM
Does anyone know what I'd need to do to get to 450hp from the standard configuration of this block? I do see that it has been upgraded with a Perfomer intake and a Holley carb.
thedonz is offline
Old 11-30-2006 | 08:55 PM
topfuel's Avatar
To get that kind of hp out of your 400, you would need a set of heads in the 210-220 port size, 9.5 - 1 compression, a camshaft with 224-230 @ .050, Performer RPM intake or equivalent and upgraded exhaust. Good luck with your build.
Barry
topfuel is offline
bwiencek
10
10-22-2013 06:16 AM
mtocrs1
1
06-08-2006 09:52 PM
Big Block Billy
2
04-10-2004 06:51 AM
fishead
10-01-2002 06:49 AM
