Anyone know the part number for ARP...
Looking for the valve cover stud kit part number for a BBC 540ci. The valve covers i purchased are from Dana Marine. The Black Oxide option, since the powder coat color is red.
This is the first step in the conversion process to an EFI from Arizona Speed and Marine, added a little bling to the project. http://www.danamarineproducts.com/pa.../VC-0010-1.jpg Thanks in advance |
Re: Anyone know the part number for ARP...
i think it is 200-7619 for blk. oxide studs and 12 pt. nuts the studs are 1.5" & 4.5" long
2 Attachment(s)
I would just put SS bolts in them.You want get them off with headers on it with studs.I also polished the top of the bolt heads. and there cheap
Thanks for the part # Eliminatethis and strip great idea! I think i will check the clearance issue to see if the bolts would be an option, otherwise i will go with the bolts.
I have imco powerflow exahausts currently. thanks again. :D :D |
I would also buy the Fel-Pro rubber molded w/ steel shim valve cover gaskets. There reusable. :drink:
My Steff's/B&B valve cover look just like yours,I bet the bolts cost about $5.00 at the bolt place or a hardware place .I can measure mine if ya need.The bolts that came with the valve covers was about .125 short with these gaskets. |
Dana Marine did not send any bolts, just the valve covers. I will let you know if i need the measurements. Once again thanks for the tips!
Its Friday :drink: |
| All times are GMT -5. The time now is 12:07 AM. |
