HP losses from Bravo 1X drive
#41
Originally Posted by Steve Zuckerman
Rob,
I have used Merc, RP, and Alisyn. Gear wear seems the same with all three, but the boat is faster with the synthetics.
I am using Alisyn engine oil too.
Who is your drag racing friend? I may know him.
Happy Holidays,
Steve
Happy Holidays,
Steve
#42
Originally Posted by Rage
Which weight/Type Alisyn do you use in your gear case?
I just checked my oil, and my mechanic recently switched me over to AMSOIL, another good synthetic. I am using their 80W90 gear oil. Athough they rate the viscosity at 80/90, when you move the container, it acts more like a 20/30W oil.
I think they've probably (Timken) bearing tested it to what a petroleum based 80/90W oil would do, but managed to do it at a lower (true?) viscosity, reducing heat and friction in the drive. Just my theory, I'm not a chemist. All I know is it works!
Regards,
Steve
ps great web site www.amsoil.com
#43
Rage,
Regards,
Steve
Regards,
Steve
Which Amsoil do you use in you motor? Change interval?
Regards,
Bill
#44
Have you tried the cryogenic gear treatment for wear?
#45
You say you just checked your oil which i assume to mean the Amsoil 80/90W and the wear/magnet debris was low like the Alisyn gear lube?
Regards,
Bill
Regards,
Bill
I'm using Amsoil 20W50 synthetic in the motor now. I have also used RP 20W50 this past season with good results.
I change all my fluids (drive/engine/supercharger) and oil filter @ 25 hrs.
Checking my oil meant the extra oil I keep in the garage
!The motor comes out tomorrow for the winter buildup.
Steve
#46
Originally Posted by articfriends
I have succesfully used and offer a correct cryo treatment followed by proper surface treatment/polishing process that greatly extends the life of these gears. My lower gears were junk after 10-20 hours of casual use and 15-20 wot passes before, with this new treatment I ran them twice as long and 35 plus equally hard passes and they still look like new with virtually no wear. Next season I am going to experiment with thinner gear oil and see how long they actually last before failure. My boat is a good test bed for them with 950 plus ft lbs of tq,Smitty
Looks good. We may be talking soon.
Regards,
Steve
#47
Bill:
Steve
Steve
Is PR Redline oil?
Bill
#48
Bill:
Steve
Steve
Which of the Amsoil 20W50 oils did you use?
TRO Series 2000 Racing Oil
MCW Motorcycle Oil
AMO High Performance Oil
#49
Bill:
Steve
Steve
Bob
#50
Steve, after you get your engine back together why don't you drive down and let's put it on the dyno. I'd be happy to do it on a weekend. I can even tweak the ECM. Just get an 02 bung welded in your headers while it's apart. You're no further away than "Rage" is. He came down a couple of weeks ago. Sure would be nice to know exactly what power you've got.
Bob
Bob
