Donovan Aluminum block >
Old 12-21-2006 | 06:42 PM
Default Donovan Aluminum block
Are there any draw backs to using one?
tomcei is offline
Old 12-21-2006 | 07:17 PM
IRONMAN's Avatar
Default Re: Donovan Aluminum block
$$$$ More $$$$$ and you probably should run closed cooling with one. A pair would be awesome in a 28 - 32 cat though.
IRONMAN is offline
Old 12-21-2006 | 07:27 PM
Elite Marine's Avatar
From my perspective too much $$$ for the little savings in weight.
I thought about it though
Elite Marine is offline
Old 12-21-2006 | 07:29 PM
Chris, is that to reduce the corrosion factor?
I was looking at a used 572 all aluminum set up with external oil system and all the goodies.
tomcei is offline
Old 12-22-2006 | 01:19 PM
I have a pair of 600 inch all aluminum Donovan block engines in my 32 Skater.What would you like to know about them ?
MYSKATER32 is offline
Old 12-22-2006 | 04:54 PM
Basicly wondering if there are any additional things to consider
when looking into this combo.
Example: I've heard the compression ratio can be higher and still run pump gas.
tomcei is offline
Old 12-22-2006 | 08:28 PM
I can't answer that one,You'll need to talk to some professional engine builders about that .Mine are 13 to 1 compression so i just run 110 race gas.I understand that aluminum heads allow you to run a little more comp. because they absorb some of the heat from the compression stroke which causes detonation.Although the blocks are aluminum they still have cast iron sleaves which contain the heat in the cylinder. Now if you had an all alum.cyl like a water cooled motorcycle that might be a different story.
Old 12-22-2006 | 11:37 PM
KAAMA's Avatar
A friend of mine has a 38' Top Gun Cig with a pair of supercharged 580cid Donovan blocks that were rebuilt/refreshened about 1 year ago by Dave Wesseldyk---no problems. They like using oil thermostats to help control the block temps, condensation, etc.
KAAMA is offline
Old 12-22-2006 | 11:51 PM
articfriends's Avatar
I have always been told that a aluminum block motor in a high hp app built identical to a cast iron motor gives up 20-50 hp due to cylinder distortion,liners moving/deforming,cap walk etc,the only reason for using one is weight savings. Aluminum heads usually allow for 1/2 to 3/4 of a point more compression on same exact octane due to heat dissipation,Smitty
articfriends is offline
Old 12-23-2006 | 07:54 AM
That all makes sense. I wouldn't think that the Alum. block would save all that much in weight. I suppose in a race situation any weight matters.
What do you think the differents in the iron vs the Alum. is?
(block only)
tomcei is offline
