Washer sequence for Ziegler Hydraulic Steering
Does anyone know the washer sequence where the steering ram attaches to the outdrive bracket for Zeigler Hydraulic Steering? There are 5 washers. 1 thick fiber washer, 1 thin fiber washer, 2 spring washers , and a regular washer. I believe the regular washer goes on the bottom by the nut. The 2 spring washers have to go on top and bottom of the ram on the inside of the bracket. Where do the fiber washers go?
Thanks,
Steve
Thanks,
Steve
Well, I got the answer, and thought I'd post incase anyone else wants to know. On top of the ram you have the thin fiber washer then the 2 spring washers (wavy washers). On the bottom of the ram you have the thick fiber washer. This all fits inside the bracket mounted to the outdrive. The regular washer goes on the outside of the bracket at the bottom then the nut.
miamioffshore
01-17-2006 03:14 PM
