540 to 572 How much Boost? >
Old 12-27-2006 | 11:48 AM
zt260's Avatar
Default 540 to 572 How much Boost?
The 540 was making 12psi of boost at 6000rpm, now I'm going to a 572 with all the same components. (The compression is staying the same at 8.25) The only difference is the bore and stroke 4.560 x 4 3/8
Heads are AFR 357
Intercooled Whipple 2.3 quad rotor EFI
Stellings exhaust
How much would you expect the boost to drop at similar rpm?
zt260 is offline
Old 12-27-2006 | 01:10 PM
Default Re: 540 to 572 How much Boost?
Maybe way to simplistic but arithmetically you are increasing your volume roughly 6% so maybe it would decrease your boost 6%.
zahndok is offline
Old 12-27-2006 | 01:25 PM
mcollinstn's Avatar
more like 6% less than previous pressure on an absolute scale. Atmospheric is around 14psi. Boost was 12 psi. Total absolute was 26psi. 6% of that is 1.56
New boost using this method of estimation is 12-1.56= 10.44 psi.
Nothing ever works out that close to theoretical since each aspect of the airflow thru the motor makes a difference, but this is a close place to start from an estimating standpoint.
mcollinstn is offline
Old 12-27-2006 | 01:40 PM
zt260's Avatar
I was also figuring about 1-2 pounds lower, but it looks like its going to be about 3+PSI lower.
We are still chasing some ingition issues, so I don't have a good HP pull to compare, but rpms are rpms.
If it makes the same power at 3PSi lower thats great. I just don't see how that could be possible. I'm not that lucky.
zt260 is offline
Old 12-27-2006 | 04:53 PM
articfriends's Avatar
When I did the same thing your doing but from a 502 to 540 I lost 2 pounds of boost,3 seems a little high but there are definately other dynamics that come into play,Smitty
articfriends is offline
Elite Marine
2
09-03-2006 12:56 AM
BenPerfected
1
04-26-2005 10:58 AM
Ratchet
54
08-12-2004 11:38 PM
articfriends
44
07-06-2004 06:12 PM
