-   -   Bravo Alignment Tool (https://www.offshoreonly.com/forums/general-q/148248-bravo-alignment-tool.html)
tahoetech 07-30-2007 09:36 PM
25 hors la loi- Is that a slide hammer that threads into the end of the alignment tool? If so, good idea.
dbdiver 07-30-2007 10:41 PM
Will tool work in older trs units?
25 hors la loi 08-06-2007 10:19 AM
Yes it`s a Slide hammer :D
drawbardude 08-13-2007 10:45 PM
Alignment Tool
I'd like to get more info on purchasing the alignment tool. My zip code is 98311.
Wally 08-14-2007 10:18 AM
the tool will fit the trs drives.......but theres another piece you still need for it to work....theres a plate that fits on the tool and sits flat against the bell houseing that the outdrive bolts up to....you align the engine so the plate sits flat on the bell housing
whoya 08-21-2007 08:57 PM
If somebody is looking for a alignment tool I just received more from my supplier.
Crum7531 10-17-2007 11:05 PM
I would like to know if you still have alignment tools available? If you do please E-mail me at [email protected] I am fairly sure I have an upper pinion seal leaking and now would be the time to check alignment. sincerely Bill Crum
whoya 10-18-2007 06:30 PM
Hey there Crum
I should have some more next week.
boatnt 10-18-2007 07:21 PM
is there a difference in alignment tool for a regular coupler and a heavy duty coupler?
I have a merc alignment tool thats about 12 years old and Iam not having any luck getting to go in the heavy duty coupler.
the outdrive slides in with no problem.
boatnt 10-19-2007 07:20 AM
by the way the alignment tool I have is #91-57797
