I can never win!! >
I can never win!!
I can never win!!
Old 01-08-2007 | 08:14 AM
Default I can never win!!
Ok, It started with an 88 Chris Craft 245 limited with an alpha drive which I blew many times (drive). I was uninformed when I bought it so that was my fault.
Then came my current 85 312 stinger with TRS drives, hearing a ton of good and bad I have decided to get a boat with Bravos. (Plus it need motors)
Well, I'm supposed to pick this boat up tomm. and now all I'm reading today is failures with the early bravos. (88 fountain w/ 330-454s).
I'm getting tired of never having the ability to enjoy boating. It seems there is always something on the horizon ready to break. Before these drives go, what would I need to buy to prevent failures of these 88's? Sorry for the rant, it just seems I never make the right decisions.
prostock85 is offline
Old 01-08-2007 | 08:43 AM
Default Re: I can never win!!
I had a pair of bravos on a 1990 Sonic. Motors putting out around 600hp each. Never had a drive problem.
If you buy the boat have a reputable bravo mechanic go throught the drives. Better yet have the boat surveyed before you buy it. It is almost 20 yrs old and is going to need work regardless. Ever hear of Pandora's Box??
Pure Energy is offline
Old 01-08-2007 | 10:22 AM
BY U BOY's Avatar
I am running a 1991 brovo with 500hp and no problems so far.I would not worry to much about the drives if they check out and are on stock power. But if you are still worried contact articfriends and have him do his magic on your gears.
http://www.offshoreonly.com/forums/s...t=articfriends
BY U BOY is offline
Old 01-08-2007 | 10:26 AM
t500hps's Avatar
21 and 42 footers
I can solve your drive problem....buy a sailboat!
with 330's just have them opened up and inspected by a reputable dealer. They should be fine as long as they are serviced annually.
t500hps is offline
Old 01-08-2007 | 10:57 AM
The survey is tomm @ 8 in the morning, Its a two hour drive. So if everything works out I plan on bringing it back that evening. I just wasn't sure if "this" year is the one that had the oiling problem I hear about. Thanks for the input.
yesrej
Baja
41
06-07-2005 10:13 AM
CAP071
02-20-2005 05:42 PM
Strip Poker 388
10-07-2003 12:33 PM
