Rear Seal Replacement without removing crank? >
Old 01-08-2007 | 12:31 PM
Default Rear Seal Replacement without removing crank?
I need to replace my rear main seal. When I took the bearing cap off, the seal was turned and sticking up about 3/8 of an inch.
Can this be done easily without removing all the pistons and crank?
1BIGJIM is offline
Old 01-08-2007 | 12:42 PM
PatriYacht's Avatar
Default Re: Rear Seal Replacement without removing crank?
The seal should be turned a little so the split is not even with the machined surface. Yes it is possible to replace the seal without taking out the crank. There is a tool to help with the job.
PatriYacht is offline
Old 01-08-2007 | 03:07 PM
I have always put them flush with the machined surface. Is this wrong? ANYONE.
What tool do I need. This could save hours
1BIGJIM is offline
Old 01-09-2007 | 09:55 AM
rush's Avatar
You can push around with a small screw driver and pull it with pliers then oil up the new one and push it back in just like it was, protruding out some.
rush is offline
Old 01-09-2007 | 10:45 AM
737jetmech's Avatar
The new seal should have a small plastic installation tool included in the package (FelPro).
You should try to offset the seal mating surface from the block mating surface. This helps prevent leaks.
Bob
737jetmech is offline
Old 01-09-2007 | 10:55 AM
CIG3's Avatar
I use a small screw driver that dipped into that rubber coating to prevent scuffing the seal surface accidentally. Then pull it thru using pliers as above.
Always offset the seal from the mating surfaces to prevent leaks.
CIG3 is offline
Old 01-09-2007 | 06:03 PM
mcollinstn's Avatar
The seal PULLER looks like a small corkscrew. You can use something similar, although that tool is cheap.
mcollinstn is offline
overnightcelebrity
Cigarette
5
07-21-2005 08:23 AM
wrenchman
3
05-18-2005 09:15 AM
hustler388
2
02-15-2005 04:11 AM
WETTE VETTE
12
01-01-2004 08:30 AM
Elite Marine
7
11-04-2002 08:46 AM
