Help!!!! Water in Trim tab Piston >
Old 01-14-2007 | 02:37 PM
Sick Stinger's Avatar
Brotherhood #1
Exclamation Help!!!! Water in Trim tab Piston
I Just got my T-Bred with i believe K-planes but not sure if they are but they are over sized and beefed up. Point is there not stock and i have water in the piston. Also the piston if i push on it feel spongy, as if there was air in it like a coushin. I put the tab down or tried to only went 3/4 of the wat sounded like there wasnt enough fluid. anyway if there wasnt no big deal but as i left the tab down water came out of the lower seal, not the piston center seal the large one at the bottom. OK, Now can i have that rebuild new seals or do i need a new piston and where can i get it if so
Sick Stinger is offline
Old 01-14-2007 | 03:17 PM
monstaaa's Avatar
Default Re: Help!!!! Water in Trim tab Piston
sounds as if you have the older pisrons/ tabs. 2 piece design. either way call mercury i believe what u have is kekiefer tabs.
monstaaa is offline
Old 01-15-2007 | 11:57 PM
Audiofn's Avatar
Charter Member #232
If it is a Merc one you can still get the seals/scrapers.
If it is Bennett then you can get those as well. Any chance you can get a picture?
Put your best foot forward!
Audiofn is offline
Old 01-16-2007 | 09:14 AM
86RedRocket's Avatar
Couldn't you take it to a hydraulic company that rebuilds/services rams?
86RedRocket is offline
Old 01-16-2007 | 06:26 PM
monstaaa's Avatar
not a bad idea, they may be able to help you. just be careful, as if they have not seen it, it may be deemed $$$$$ .
not that mercury isnt, but with merc parts for merc stuff, except for the chance of saving $, on a not so isolated piece or part, its a garanteed solution.
monstaaa is offline
Old 01-17-2007 | 03:58 PM
Brotherhood #1
I found out that they are Hynautic Trim Tabs Rams and Indicators
26sonic
04-30-2008 03:08 PM
26sonic
Sonic
8
05-12-2006 09:23 PM
Python82
03-14-2006 06:08 PM
Monty
6
05-16-2005 01:24 PM
MnFastBoat
05-04-2005 08:34 AM
