How to tell the difference in drives? >
Old 01-14-2007 | 08:26 PM
Fenderjack's Avatar
Pirate of the Chesapeake
Default How to tell the difference in drives?
How can I determine what drives I have on my boat. I need to know if they are merc hp's or xr or ect. They do have the low water pick ups on them. Is there a id ## on the drive some where. Thanks for any info.
JOHN
Fenderjack is offline
Old 01-16-2007 | 12:29 PM
Mr Gadgets's Avatar
Charter Member #601
Default Re: How to tell the difference in drives?
John,
Look at the serial number, should be on the side of the upper housing. If it is OM, then you have a newer drive with thick floored gears. That is a start.
Is the prop shaft the large 1 1/4" shaft, if so then it could be XR or XZ. If not then it is Standard Bravo (before OM) or X (OM and later).
Pull the top cap and see if the gears have straight teeth or helical. It is easier to see by pulling the back cap off. Of course you need to know what the different styles look like. Do a search, you should be able to come up with pics of the differnt gears..
Hopet this helps..
D_ick
Look at the hing pins in the bellhousing of the transome assy. If you have trim limit/indicators then it is not HP Gimble.
Mr Gadgets is offline
Old 01-16-2007 | 02:57 PM
Iggy's Avatar
Record the serial number then go to the Mercury Parts Expres site. There you can enter the S/N and it will tell you what drive you have along with the gear ratio and a parts list.
Iggy is offline
Old 01-16-2007 | 06:43 PM
99fever27's Avatar
Iggy, Do you have a link to this site? Thanks..
99fever27 is offline
Old 01-16-2007 | 06:53 PM
Fenderjack's Avatar
Ok thank you Mr gadget, it apperars to be a hp drive.. Iggy what is the site you are talkin about.
JOHN
Ken N
5
06-10-2008 10:36 PM
cigarette39
11-13-2006 07:02 PM
Reed Jensen
3
04-13-2004 10:59 AM
Dean Ferry
11-27-2002 08:09 AM
