Having some work done-$$ sound fair?
I've got a 93 carbed 502 in a 27 ft powerquest. To make a long story short, the motor leaned out and hung up a valve. The newly rebuilt shortblock is ok. One of the heads needs to be replaced(rect. port). I will also be upgrading to a hyd. roller set up with roller rockers, springs,pushrods, etc. Heads will have inconnel valves, no porting. A new holley carb and intake will reside on top. The log manifolds will be replaced with some type of ported sport tubes that they say they have had good luck with.( I'm assuming these are the newer stock bravo manifolds.) Installed and tuned with a one season warranty for $9500.
I'm new to boating. Most of my experience with motors comes from drag racing. I'm experiencing a little sticker shot. Does that number fall in line with what a good shop would charge? Tom |
Re: Having some work done-$$ sound fair?
That's a tad pricey. Shop around.
The shop charges $95/hr. For my area, that's not outrageous, but probably the high side of normal. When I add up those parts it seems like an awful lot left over for labor. Is there that much involved on the labor end to justify the number? I'd sure like to hear from some of the guys who have done similar work.
Tom |
Knowing what kind of exhaust you are getting would help. Most aftermarket are about 2000.00. Rebuilt heads w/valves 1500.00. Hyd. roller cam with all required parts 1200.00. New carb and intake 1000.00. R & Ring engine with possible custom work required 1000.00. Small parts such as gaskets etc.300.00. I come up with 7000.00 but in my area 75.00 is more like the going rate. If this doesn't include new aftermarket exhaust, it's way too much.
Find another builder for a second opinion. Might be par for your area.
Seems a bit high depending on exhaust. You can always have him give you a breakdown of the estimate. |
3 Attachment(s)
I Think Thats A Little High.
I Did My 454 Complete Rebuild This Summer New Pistons,cam,aluminum Heads,carb,intake,full Roller Conversion And new manifolds The Only Things Left Stock Were The Block And Crank And I Was Just Over 6k With Machine Work, I Pulled And Installed My Self. I HAVE A FEW MORE THING TO DO TO MAKE THE ENGINE COMPARTMENT LOOK GOOD BUT ITS GETTING THERE. |
Originally Posted by hydrophilic
(Post 1997333)
Check out the OSO classified section. I just purchased a complete rebuilt 502 MPI complete ready to drop in from Byron at Davis Farm and Auto. He's a boating guy and built a gen 6 motor for me. I have only run the motor on a hose but it ran good and looks great. you will spend less money and can sell what you have as no core charge is required. He was a great guy to work with.
Byron is a good guy to do business with.
I have a 502MPI mag .... ALL fresh ... New Forged Rods and Pistons 500 efi Cam .. Crane roller Rockers ...7000.00 .... .. you'll love the fuel injection ....m
[email protected] |
| All times are GMT -5. The time now is 09:13 AM. |
