Pipe thread sealant? >
Old 01-21-2007 | 07:42 PM
MOP
Default Re: Pipe thread sealant?
You non believers should take a moment to read the links I posted, the tape I use is specifically formulated for both petroleum distillates and inert gases. White Teflon is another whole story, many have not been properly trained to use specific products and do screw things up.
The head bolt sealer is a very good product but also improperly used in most cases, 90% of the users apply it to the bolt only, a small dab should be put into each thread bore to be pushed along onto the threads. Many a block has been ruined buy not applying it properly, this is especially true with raw water cooled blocks that do not have the help of corrosion preventives in anti freeze.
MOP is offline
Old 01-22-2007 | 08:10 AM
Panther's Avatar
Frank's Marine Service
Originally Posted by Young Performance
I really like a product called leaklock (I believe its called,don't have it in front of me) It is a light blue color and is basically a cross between thread sealer and loctite. If you have a fitting that is not quite tight enough, but won't make another turn, this stuff works great. Once it sets up, the fitting will not move. Also use Rector seal, it is very similar to the above.
Definetely no teflon tape on fuel lines!!!
I've used the blue stuff. It goes on really nice but that stuff is tough when you have to take somthing apart! I also found that it cracks when you take it apart and small pieces can fall into the fuel line. maybe I used a different brand but that's what I reember. I believe I first saw it being used by a guy who does air conditioning systems..
Panther is offline
Old 01-22-2007 | 05:01 PM
monstaaa's Avatar
teflon tape in a no-no for sure. the special tape mentioned is as stated upon disassembly it cracks or can ruin the thread in which you are trying to seal, similiar to the Loctite thread sealing compound. for the last 10 years plus i have been using the liquid sealing compound which has teflon in it, which provides lubrication and reduces heating of the thread which commonly occurs during the instalation process on a pipe thread. also if the sealant becomes a contaminant, it usually will disolve instead of becoming debri which can due much more harm.
monstaaa is offline
Old 01-23-2007 | 01:22 AM
2112's Avatar
MOP; where do you get the yellow tape? Monstaaa which teflon liquid do you use?
If the main purpose is lubrication, why not moly or grease?
2112 is offline
Old 01-23-2007 | 06:48 AM
monstaaa's Avatar
3m thread sealant, it is similiar to the g.m product except it has graphite.
its main porpose is to seal but the it also yoo lubricate.
monstaaa is offline
Old 01-23-2007 | 11:47 AM
MOP
Lightbulb Re: Pipe thread sealant?
[QUOTE=2112;2001457]MOP; where do you get the yellow tape?
My parts house stocks it, I woulld ask yours to order it for you.
MOP is offline
Old 01-23-2007 | 03:42 PM
I'm In The Performance Plumbing Business And I See Bad Teflon Tape Job's Everyday. Holley Was Told To Not Use Anything On Threads Because They Are All Metal To Metal Seals. We Use N-d 420350-50 On All Systems Without Any Problems. This Compound Is A Teflon Base With A Anti Galling Agent For Use On Stainless Steel Fittings. It Works On All Media's
Fuel,compressed Air,natural Gas, Oil, Water.
Jb-fse is offline
Old 01-23-2007 | 08:32 PM
Whiteknuckle's Avatar
I am a steamfitter by trade, and have been in the piping business, for 35 years. Pipe dope is actually designed to be a thread lubricant, not a sealer, although some do help after they set up. The best single pipe dope we have used over the years is Loktite PST. It is a great antigalling dope used for Stainless steel and alloys. You cannot use it on PVC or CPVC. I believe the sealer that comes with ARP head bolts is infact, PST. The bad thing about it is the price, if you use a lot.
Remember what ever brand of liquid dope you use, you only put in on the male thread, and you should not have to use a lot. That is how you end up with the dope in the system.
Whiteknuckle is offline
Old 01-24-2007 | 07:04 AM
monstaaa's Avatar
the moral to this story is,,,,,,,,,,,,,,,
"DONT BE A DOPE AND UST TOO MUCH DOPE"
monstaaa is offline
Rocko C
2
07-25-2007 03:07 PM
US1 Fountain
Fountain
1
02-29-2004 08:19 PM
BAD-HABIT
12
03-28-2003 03:35 PM
SLINGSHOT
08-28-2002 08:29 AM
dyno
8
07-12-2002 08:34 AM
